Edit Static Source Groups
Configure static source-group entries in the PIM multicast routing table. PIM cannot prune these entries from the distribution tree. In other words, even if no receivers exist in the group, the multicast stream for a static source-group entry stays active.
Before you can configure a static source group, you must globally enable one of the following protocols:
PIM-Sparse Mode (SM)
PIM-Source Specific Multicast (SSM)
This procedure is supported only on a DvR Controller. It is not supported on a DvR Leaf node.
The maximum number of static source groups must not exceed 1024.
The switch supports PIM only in the Global Router. You cannot configure static source groups for specific VRF contexts.
- Select Multicast.
- Select the Static Source Group tab.
- Edit the required information.
- Select Apply.
Static Source Group Field Descriptions
Use the data in the following table to use the Static Source Group tab.
Name |
Description |
GroupAddress |
Configures the multicast group IP address for this static source-group entry. |
SourceSubnet |
Configures the multicast source address for this static source-group entry. How you configure the source address depends on the protocol and mode you use. |
SrcSubnetMask |
Configures the subnet mask of the source for this static source-group entry. |
